It is currently Wed Aug 20, 2025 8:02 pm
Post new topic Reply to topic  [ 67 posts ]  Go to page 1, 2, 3  Next
PostPosted: Fri Feb 14, 2014 12:14 pm
I am moving forward on installing my CV max cyclone.
Been way to long that its been sitting in my basement.....
PostPosted: Fri Feb 14, 2014 4:07 pm
First name: Rusty
I just finished binding this OM
for no. 2 Son. 0ne more Son, one Daughter, and so far, 6 Grandchildren to go.
And to think, the only reason I went into this was because I needed a guitar, I still don't have one.
Sent from my iPhone using Tapatalk 2
PostPosted: Fri Feb 14, 2014 6:20 pm
First name: Chuck
Last Name: Hutchison
City: Houston
Pore filling black walnut wit Zpoxy. It's odorless ya know. Says so right on the box.
Sent from my walkie talkie using Tapatalk
PostPosted: Fri Feb 14, 2014 6:30 pm
Last Name: Russell
State: Michigan USA
Just finished building my binding channel jig and I will be finally binding my parlor over the weekend. Now I just have to figure out what binding and perflings I am going to use.
If anyone is curious I built the jig out of 1/2" Sintra, it is expanded PVC sheet and is put together with it CA glue. It makes pretty strong jigs and fixtures but is easy to work.
Bob
These users thanked the author RusRob for the post: Ken Jones (Mon Feb 17, 2014 11:13 pm)
PostPosted: Fri Feb 14, 2014 6:39 pm
First name: nick
Last Name: dingle
Watching paint(lacquer) dry. My Blackheart Sassafras OM from the new builders challenge. bliss Going to be delivered to the recipient in 3 weeks. Finished photos when assembled. It's a wedding gift for my wife's cousin. The other is a 12-string dread from Lutz and Bubinga for a mate. Finally, the jewellery box I started for my daughter's 18th which will be delivered on her 19th idunno
Blue velvet lining as per her choice :)
PostPosted: Fri Feb 14, 2014 7:12 pm
Last Name: Parchem
City: Seattle
State: Wa
Zip/Postal Code: 98177
I just finished pore filling this Martin style guitar with Z-Poxy. I am making it for a friend. I will start spaying tomorrow with EM6000.
PostPosted: Fri Feb 14, 2014 7:34 pm
Got the assembled rims/linings (top -laminated, back - reverse kerfed) for an Antes Parlor radius sanded.
Still to brace and fit the back and top.
Spend a few hours stripping, checking and setting up my 150mm cross vice (probably the best lb for buck tool I've ever bought, that sucker is heavy!) to make a slot head and classical (with threaded inserts) tuner hole drilling jig.
Also received some alu angle I was waiting on to finish a sliding table for my bandsaw to cut back angles as required on headstocks - I had to beat that into shape, having arrived at about 86 degrees instead of 90!
Oh - and burned a Valentine Days dinner for me and the missus..............
Update -
PostPosted: Fri Feb 14, 2014 8:05 pm
Last Name: Russell
State: Michigan USA
I hate when that happens... Plan something special and end up eating pizza
Bob
PostPosted: Fri Feb 14, 2014 10:09 pm
First name: Kent
Last Name: Wilkinson
City: New Carlisle
State: Ohio
Zip/Postal Code: 45344
Barncaster and neck. And a 3 stringed contraption. and picked up some wood.
PostPosted: Fri Feb 14, 2014 10:26 pm
First name: wes
Last Name: Lewis
City: Garland
State: Tx.
Zip/Postal Code: 75044
Bob
looks really cool...how did you cut it???? cnc????
MK5acoustics.com
PostPosted: Sat Feb 15, 2014 1:42 am
Last Name: Russell
State: Michigan USA
Na.... Bandsaw. This stuff is really easy to work with, it is expanded PVC and it cuts like butter. The outside is smooth and shiny the inside is sort of foamed but it is dense. You can sand it just like wood and get a smooth slick surface. CA glue works best on it and makes a strong joint. You will break the board before you break the joint.
Maybe I will post it in the Fixture section.
Quote:
Barncaster
DuDe... Image
You could also call it an OutCaster...
Cheers,
Bob
PostPosted: Sat Feb 15, 2014 5:49 am
Playing my 'new' brownface
Sent from my GT-I9305 using Tapatalk
PostPosted: Sat Feb 15, 2014 5:59 am
Soundclip Arnt!!
PostPosted: Sat Feb 15, 2014 7:12 am
First name: Jim
Last Name: Kirby
I may peak in the door for the first time in two months to see if it's all still there.
Jim Kirby
kirby@udel.edu
PostPosted: Sat Feb 15, 2014 8:01 am
First name: Martin
Last Name: Taylor
City: Central Coast
This weekend my son finished his first build. It has been a long but rewarding experience teaching him and I hope in years to come he remembers it as fondly as I do now.
Martin
Martin Taylor
http://martintaylorguitars.com.au
PostPosted: Sat Feb 15, 2014 8:16 am
First name: Bruno
Last Name: Piancatelli
Country: Argentina
well Im not doing all that much, but wanted to share this pic my latest guitar, his new owner is a photographer and sent me these nice pictues.
PostPosted: Sat Feb 15, 2014 9:04 am
First name: D
Last Name: S
Leveling frets on a new Tele build.
Almost as fun as finishing or watching paint dry.
wah
Wah-wah-wah-wah
Wah
PostPosted: Sat Feb 15, 2014 9:06 am
First name: D
Last Name: S
Kent,
What species are the two bird's-eye planks?
It looks very similar to a piece of Elm I found down here.
Dan
wah
Wah-wah-wah-wah
Wah
These users thanked the author dzsmith for the post: Kent Wilkinson (Sat Feb 15, 2014 5:20 pm)
PostPosted: Sat Feb 15, 2014 9:57 am
I'll be spending a bit more time playing the latest guitar . . . trying to convince myself that I can part with it. If I write a song on it maybe I'll feel as though it's served me a little.
I'll also be tidying up the shop so I can get started on the next one.
PostPosted: Sat Feb 15, 2014 11:14 am
First name: Martin
Last Name: Kelly
City: Tampa
State: FL
Zip/Postal Code: 33634
Numbers 6 and 7 need bridges, and recent thread makes me want to play with Chladni modes again, and maybe time to do a frequency spectrum. May have to wait for wife to go shopping - she doesn't like my tone generator, and I need the dining room table for that set up; no room left on the pool table. Weekends seem to go too fast, but maybe I'll get one bridge on today, and check out the modes tomorrow.
PostPosted: Sat Feb 15, 2014 11:40 am
First name: Zeke
Last Name: McKee
City: Goodlettsville
Zip/Postal Code: 37070
Nice box!!! I'm getting g ready to start on one for the lady. I got the plans drawn now just gotta put down the beer and get to work. I love the binding on yours. What did u use? It's hard to see from the pic
PostPosted: Sat Feb 15, 2014 12:20 pm
First name: Kevin
Last Name: Looker
City: Worthington
State: OH
Zip/Postal Code: 43085
Trying to make some progress on an electric build.
Radiused & slotted a couple of fingerboards, EIR & ABW. Getting ready to inlay some dots. Not too exciting.
Sorry about the funky white balance, fluorescent lighting.
Kevin Looker
I'm not a luthier.
PostPosted: Sat Feb 15, 2014 1:05 pm
First name: Stuart
Last Name: Gort
Struggling with making videos. Death to technology.
Lovely stuff, guys.
StuMusic
PostPosted: Sat Feb 15, 2014 1:32 pm
First name: Ron
Last Name: Belanger
Some great looking stuff happening. This weekend I am giving my shop a break and helping my son get my three grandsons to their hockey games. Six of them over the next two days. It's great to see them.
PostPosted: Sat Feb 15, 2014 5:22 pm
First name: Kent
City: New Carlisle
State: Ohio
Kent,
Dan
The wood in the picture is not the birds eye. It's white oak with bark inclusions all the way threw it. I'm going to make a Tele body with it. I didn't get a picture of the maple I bought yet.
